Post by davenq on Aug 10, 2009 20:28:50 GMT 10
I was given an "old" annexe ...from a reative and the clips looked "spot on" ....(they were 'C" styled .) . .when I tried it on ..they were too tight to fit... . looked the same style . .can you still get the extruded..."brass" (I think it is brass) sections that attach to the van of a narrower guage?? . . .other optios (read cost nothing ) is to try and crimp the existing rail so it will fit the annexes "c" section. . .the rail looks like a wide U ..with flats on top....
Post by davenq on Aug 12, 2009 16:00:32 GMT 10
Have discovered today fom the local canvas place ,that they came in two sizes,..5/8th and 7/8th...of course everything is obsolete...
.now to find an old van (wreck) with a 5/8th rail......
Post by humpty2 on Aug 12, 2009 20:12:30 GMT 10
There is a big chance that when you go to crimp the Marconi track that it will break....it is very brittle.
Post by cuz on Aug 12, 2009 21:53:02 GMT 10
My annexe has clips to suit marconi track as well. When i wanted to make an awning clips were obsolete so i just made new ones myself out of stainless flat. If you have trouble folding them up i suggest forming them over a die which is fairly easy to make. Problem solved Bill
