Post by Highway on Jan 25, 2009 9:54:47 GMT 10
Hello every one,I dont know if any one has seen the trailer on ABC channel 2 today at 10.00 regarding an invention on trailer and caravan safty. I have placed a link below for more information,what it does is a trailer plug that is wired to your dashboard that indicates if all your lights are working such as when your left or right indicator is working stop light tail light and width lights. www.trailervision.net/index.htmlHighway
Post by DC3Td on Jan 25, 2009 14:43:49 GMT 10
There is also this type of unit which can be left plugged in indefinately. Caravan,trailer or car lights should be checked periodically any way and having an electronic unit perched on the dashboard might very well be a good idea but i`m not so sure i`d like to see flashing lights continually in my line of vision.Just my two cents (or $20 unit price) worth. cheers gordon
kiwi
Post by kiwi on Jan 25, 2009 16:21:29 GMT 10
i sell these ones The KT LED Plug The KT LED Trailer Plug provides an accurate visual check via 6 illuminated LED’s to ensure there is power supplied through each correct circuit and that power from the source is active through the trailer plug. The KT LED Trailer Plugs also come standard with an off/on switch to ensure that the LED’s only illuminate when turned on for testing. In the round 7 pin small and large trailer plugs and sockets, the KT Plug now incorporates a revolutionary 3 step wiring body which makes installation as simple as a 7 pin flat plug. The LED wiring from the circuit board to the LED’s has wire connections that are standard industry colours to assist the DIY or DIFM customer easy installation. Features: - New inbuilt LED circuit tester - Simple colour coded wiring - Revolutionary 3 step wiring body - On/off switch incorporated - Fits all standard trailer plugs
Post by kingy on Jan 25, 2009 16:59:13 GMT 10
Think i'll spend the $ on something more pleasurable and continue to regularly check my lights the old fashioned way - it's not much effort - but no doubt they'll sell heaps Kingy
Post by DC3Td on Jan 25, 2009 17:10:46 GMT 10
Bought mine at a trade show a couple of years back. Believe it or not, the brand name is CheckMate! And no, i`m not going to 'expand' on that. Btw, Kiwis`KT looks interesting. cheers gordon
