Hi Andrew.
I used 5 ply walls and 3 ply roof on my replica TD..
Given my time over again i would use masonite on the roof.
As already stated by raym ply tends to open up the grain in the wood on the top layer of the ply laminate when bent.
Masonite has a smooth finish and can be protected with good quality oil based undercoats, primers and top coats.
The 5 ply walls are single thickness only. There is no internal lining in "The Splinter Hilton"
Also the original circa 1948 Td i rescued from Lockhardt near wagga was constructed the same way. single skin external walls - 5 ply. Masonite roof.
No internal lining apart from the fronts of cupboards etc..
Plywood is an excellent insulator and there really is no need for internal lining apart from the appearance factor.
Any internal framing that was needed was 25mm square section.
Try to keep in mind when working on your project that TDs are meant to be light and manouverable. They where designed for carting up the scrub on weekend shooting trips. along the beach to the favourite fishing haunt. Short term holidays and light to tow.
Use heaps of tubes of liquid nails to glue and screw everything together with good qaulity cad plated, galv or better still brass screws.
backed up with plenty of fine "cleat " nails..especially on tight raduises. the nails are the ones with ridges in the side of them so they dont work thier way out with movement or vibration.. There is a fancy name for them .. i cant think of it.. something like "braids" or "brads???
So only other advice i can give
"Keep it light .. keep it simple ... most of all .....keep at it.
When shes done you will take pride in being a part of the "TD restorer /constructor"" family here on the forum.
Once you achieve that status you can then set to work on "How to get dressed horizontally" ;D ;D ;D ;D ;D ;D
Reddo
P.S: refer "Members photo album - "Reddos TD the 20 year plan" for info on the replica and its build
also
"Reddos Real TD" and an original TD.
