Post by Impala on Jan 13, 2009 15:06:19 GMT 10
Hi all, I have found an old chrome galley pump, but the inside feels loose, like it needs a washer, and I was wondering if anyone knows if washers are still available for them, I dont know the brand of it, and if that is the problem. Any suggestions, or info appreciated. Regards Impala
Post by Deleted on Jan 13, 2009 19:10:42 GMT 10
Yo..Impala If Cols advice dont work i have a complete kit here . Ex Wildmanus stock. (A member on this forum) Ya just need to tell me what size bore the pump body is. There is 2 different sizes. I think they are 3/4" and 1 " One i can help ya with .. the other ?? wellllll.. I cant ..But i have the phone number for the supplier of fynspray Galley pump parts ... thats what yours is. Lemme know if the "soak it and see" doesnt work for you ;D Redbits
Post by Impala on Jan 14, 2009 19:06:39 GMT 10
Hi Reddo, Unfortunately, we are not able to do the soak it and see test, as we have not bought it yet, we wanted to make sure it was able to be made useable first No point in buying it, then finding it could only be used as an ornament Now, the size of the bore is 1 3/8", and it does not have the mounting plate with it, it just has a thread at the end of it. Regards Impala
Post by Deleted on Jan 14, 2009 20:20:25 GMT 10
Yo proscrastinating Impala Buy the bloody thing.. we can sleeve it .. bore it.. put a 23/70 cam and a set of twin S.U's on it and get it reving... Not hard to make something"Suck and blow" These things are simplicity in the true form. A swollen big fat leather washer can take up a "The slop" in any pump. Dont worry about the nut that holds it on the sink.. it'll only be a whopping BSP thread or something similar.. ya hearin me boy .. stop goofin off and just buy it. Reddo
Post by Impala on Jan 14, 2009 20:40:16 GMT 10
OK OK I will go and buy it ;D ;D ;D Impala
Post by Deleted on Jan 14, 2009 21:43:55 GMT 10
Thank you sir.. ya just managed to get me an"A" level pass in "Motivational speeches" at T.A.F.E Lemme no ... ........when you have possession of said pump and we can do an "autopsy" from there via pms... Reddo... Advert: Having trouble getting water up out of your pump???.. Try Viagra.....Playboy mags........ or a good fynspray pump overhaul kit. ;D Just $32.50 from your local B.I.A.S store. ;D
Post by Impala on Jan 15, 2009 18:13:02 GMT 10
Hey Reddo, Found another one, ;D this one is complete, and half the price ;D Think it might be a newer model, as it has a small plunger where the seal is, the other one had a ball arrangement. Anyway, it will do the job Impala Might even get the other one just for the heck of it
Post by Deleted on Jan 15, 2009 21:19:36 GMT 10
A fynspray Galley pump Chrome over brass.. Anything else .. i cant help you with.
