Post by DC3Td on Jan 11, 2009 14:33:34 GMT 10
Post by minicamper on Jan 12, 2009 6:51:01 GMT 10
Hey DC, I'm not sure what your background is, but before you go taking a grinder to anything, might i suggest you speak to some of the more engineering inlcined on here. Your a frame, although different in total design to mine, is basically made of the same materials. The strength in your is coming from that big beefy angle iron in the middle. Mine had been extended at some stage and the strengthening was done by boxing in the angle iron, exactly the way your outer sections have been done near the hitch. It's not enough and my chassis snapped, fortunately at walking pace, but could have easily been a disaster. Of course it all comes down to weight and I don't know what your is (van, not yours personally) See the photo's at vintagecaravans.proboards30.com/index.cgi?board=photo&action=display&thread=3405&page=1 and scroll past the scenic tour at the beginning. Cheers Chris
Post by JBJ on Jan 12, 2009 7:33:35 GMT 10
Hi Gordon,
A couple of suggestions for you to consider, then do what you like as its your van.
The hardwood drawbar is more than adequate as is. Australian hardwood timber generally only weathers from exposure to weather. Simply put some form of protective treatment on & it should stay OK for longer than the van will live.
I would put something like the treatment they put on the base of power poles, which is a paste type product, on both exposed sections of the timber drawbar at front.
Then fold or cut a 1.6 mm cover strip from galv. steel plate, to cover the entire top of the drawbar from side to side. Rivet or screw fix over, squeezing the paste out the sides.
For the underside, do the same forming a channel section. The vertical legs only need to be deep enough to allow easy fixing to the angle iron.
Give the finished product a good coat of epoxy enamel. or that POR15 product.
That will look neat, last forever, & not destroy a working product that you have at present.
It may not appeal to a perfectionist, but they never get to finish products in reasonable periods of time.
Get it fixed & use it. Nothing has to be show car stuff with caravans, it is TOTALLY about using them & having fun.
At a caravan run, no one gives a damn about the quality of underneath detail, the perfect fit of components, or the neatness of the inside of your storage cupboard.
As I said at the start, you will do what you want to. No one can influence anyone much. I've seen more unfinished projects get thrown away by trying to achieve the un neccessary level of construction the builder is trying to get, than I have seen completed. I've even been guilty of doing the same myself in the past.
But never again. Set reasonable goals & levels of finish that can be achieved without having to throw the (destroyed) project away.
Post by DC3Td on Jan 12, 2009 20:15:55 GMT 10
Hi Chris & JBJ. Thanks for your support & suggestions. Removing the heavy angle iron.The A frame angles along with the spare wheel holder will remain albeit them being straightened. But for my own peace of mind a new wood tow rail which i already have will replace the existing one.This is strickly a sympathetic refurbishment.Although personally i would loved to have totally restored it.Pity i only have a carport & not a damn big shed. Once again thanks guys. cheers gordon
