HAD708
Post by HAD708 on Jan 2, 2009 14:20:07 GMT 10
Hi Guys My 1957 phoenix ply caravan resto is going along well but i need to know how to clean up my Aluminium windows and trim. obviously on a 50+ year old caravan it is tired and dull and i thought i would ask the experts how to best clean it up! i have a big tin of autosol polish that i thought i would use? but the best way to start? Do you use abrasives such as fine sand paper or steel wool or other and then polish? And when you polish should i use a buff wheel in the drill or hand or what? All and any suggestions greatly appreciated and received. i will try and put some photos up soon the hatch and holes are all fixed it has all been sanded back and been fully repaired on the outside. All thoughts on the aluminium polishing i await. Thanks Brett
Post by DC3Td on Jan 2, 2009 14:36:56 GMT 10
Hi Had708. Welcome to the forum. Fellow forum members Reddo & Willyn have posted their method/s in polishing ali trim.Willyn on his recently aquired Airstream & Reddo on his resto.There are some really great pics & info relating to the application to suit your needs.Check Page 6 in Technical for starters. cheers gordon
Post by atouchofglass on Jan 2, 2009 18:29:48 GMT 10
Gidday Had708 Can't say what others do But the window frames and strip around the middle of my van were polished with fine steel wool and jiff initially then autosol to finish Time consuming but worth it The real bad stuff had a fine sandpaper first Cheers Atog
