Post by Daggsey on Dec 30, 2008 9:29:42 GMT 10
Been holding off posting this ........but might help others.
On the way from Coledale to Moruya, just out of Jervis Bay, 2 weeks before Christmas, this little "incident" occured...........
Very helpful guys from the local water authority who towed Madonna a couple of k's to a safer location..................
The cause.....................
This is the REALLY embarrassing part .........had to be rescued by Kingy in his Ffffffffff...ooo >:(rrrrrrrrrrduh.....OK, I've said it .........the really good part was he was towing the VALIANT, not the HOLDEN
This was the problem.......a light-weight towbar, possibly homemade............
The end result, Effacy is now fitted with a towbar constructed of square tubing with 6mm thick walls.......
The immediate reaction would be to blame the weight of Madonna (including the 2 batteries on the drawbar). However, I did reflect on what lead up to this incident........
The suspect towbar was successful for 17000 kms towing "Lady Madonna". The day before, I had hit an unmarked "storm drain" (bitumen) crossing a street in Berry. I reckon that probably caused an initial crack in the bar.
I have since seen a DVD at Kingy's showing a 100 Series Landcruiser towing an off-road Kedron caravan with a Hayman-Reece hitch........they broke the towbar after hitting a large dip on a gravel road (at a greater speed than me)..........their analysis was the stabiliser bars created so much pressure that the towbar simply cracked. I also have stabilisers fitted........a likely cause of what happened with Effacy.
A couple of points have come out of this excercise............
If you purchase an older towcar with a towbar fitted, it is almost impossible to tell how strong it is......in my case, the round tube bar was fully sealed at both ends.
If you fit stabilisers, especially with chains, how do you know what the optimum number links are to lift the bars? Is there a "rule of thumb" or just guess work like I've been doing?
The reason for fitting ride-stabilisers I guess is to "lift" the back end of your car so van & car ride level........of course all this relates back to weight.....what is in the van and what is in the boot of the tow vehicle.
At the end of the day, all ended well in this situation and I do thank Kingy ;D ;D ;D ;D ;D for travelling 130kms to our rescue.
Maybe a technical response from our resident engineer gurus, Kaybee and JBJ
Daggsey
Daggsey
