Post by philthomas on Dec 6, 2008 19:14:56 GMT 10
I have a E.P. Draffin pump tap that isn't pumping, I assume there may be some replaceable gaskets inside but can't see anywhere obvious that it might come apart. Has a brass pump body, chrome spout and round black plastic handle, fitting top and bottom of the body look as though they are soft soldered on. Phil
Post by Deleted on Dec 6, 2008 21:20:18 GMT 10
Dear Phill. can you post a picture of your pump. ??,,,, umm the chrome one that is.... not actually YOUR pump.. There is a mob up here at Lake Macquarie that can supply rebuild kits for most sorts of pumps. Better still Ring B.I.A.S Pacific Hwy Belmont , NSW and describe what your chasing. Or stick your melon in the door of your local ships chandlers and wave the pump around... someone is bound to help Reddo
