Post by mountainsdaze on Oct 30, 2008 16:43:04 GMT 10
Hi Everybody We are currently doing up an old '60s 'Koorong' that we towed up from Bendigo. I am trying to track down some replacement window seals for the side windows with a hinge at the top. I have scoured the web but have not had any luck I even went to Spectrum rubber in St Mary's who deal with old motor vehicle rubber... but again no luck. The crux is the section of the profile that slides into the channel - I will attempt to attach rough diagram of it here. This is the closest match that I have found online, but I have only found a supplier in England... but the channel profile looks similar. Do any of you have any suggestions? I eagerly await your comments. Dan
Post by mountainsdaze on Oct 30, 2008 17:01:25 GMT 10
A further note - attached is a photo of the construction. You can see the windows that I am talking about on the side of the van. We are fast tracking things so as we can take the van away with us at christmas time! ;D ;D ;D Very best regards Dan
Post by hotrodbus on Oct 31, 2008 13:06:52 GMT 10
hi Dan we live in Tasmania and have done up a 38 Chev hot rod and fitted new seals to all windows and doors and also around the back windows in our 48 bed ford bus camper van and we have an expert car rubber man who lives in Tasmania and we had no trouble with leaks after he helped us.If you would like to reply we will give you more info on this to see if we can help you with this problem.I might be wrong but the profile looks like something that we used Kind Regards hotrodbus
Post by diyman on Oct 31, 2008 18:06:13 GMT 10
Hi Dan
I don't know which area you are in but I would suggest Clark Rubber, they have a big range of auto mouldings. Also windscreen repair company's are a good source.
Cheers Jim
Post by mountainsdaze on Nov 1, 2008 8:01:37 GMT 10
Hi Hotrodbus
I would really appreciate the details of the rubber man that you mention in your reply. I can send him a sample of the rubber that I am trying to match - that is probably the best approach.
Cheers
Dan
Post by mountainsdaze on Nov 1, 2008 8:03:02 GMT 10
Hi Jim
I did see on the Clark Rubber website that they had 60+ profiles to choose from so will look forward to a trip down there soon.
Thanks
Dan
Post by hotrodbus on Nov 1, 2008 8:26:17 GMT 10
Hi Dan the name of the rubber man is John and Marilyn Robertson Classic Auto Replacements 22 Grigg Street Deloraine Tasmania 7304 Phone and Fax 0363623247 Mobile 0402322330 Hopefully he will be able to help you Kind Regards hotrodbus
Post by Impala on Nov 11, 2008 16:15:38 GMT 10
There is a wholesale rubber factory in Dandenong, that are willing to give you samples to see if it fits your purpose. If you are interested, I will find out the name. Impala
Post by mountainsdaze on Nov 12, 2008 19:53:42 GMT 10
Hi Impala
Thanks so much - that would be great! I look forward to hearing you.
Dan
Post by Impala on Nov 12, 2008 20:07:09 GMT 10
Hi Dan,
The name of the company is Ambassador Industrial P/L, 55-57 Amberley Cres, Dandenong. Phone 0397911055.
They were very helpful when we needed rubber for the van.
Regards Colin
Post by mountainsdaze on Nov 13, 2008 10:08:49 GMT 10
Thanks very much - I will be in touch with them.
Dan
Post by cobber on Nov 13, 2008 13:46:58 GMT 10
G'day Dan,
If I were you I would give the "CAMEC" people in your state a ring........ they carry about three different rubbers for aluminium windows.
Let's know how you go.
lazza
Post by lazza on Nov 13, 2008 22:31:52 GMT 10
Dan, If you would like to perhaps send me a PM with your address I will send you a sample of section that I have had run that suits these old windows. I have found out so far that their was 2 different window sections that were similar and so have had both of them run off. Regards Larry
Post by mountainsdaze on Nov 18, 2008 8:57:04 GMT 10
Hi Larry
I hope that you got my address as a PM I look forward to receiving the samples that you speak of. I will let you know how they go.
Thanks again
Dan
Post by tinnie on Nov 18, 2008 21:19:51 GMT 10
hi Dan, Am I correct in assuming the rubber you are chasing for the outside edge of the window? I will also have need for similar soon. Cheers, Gristy
Post by mountainsdaze on Nov 19, 2008 9:23:41 GMT 10
Hi Gristy
Yes the rubber is for the outside edge of the window. It seals between the window and the wall. Does the profile appear to be similar to yours?
Cheers
Dan
