Post by rhowna on Sept 24, 2008 14:50:16 GMT 10
Hi everyone, Iam new to this forum so bare with me. Iwas wondering what the best type of ply wood to use to redo the outside of my Roadhaven. I want a smooth finnish not a grainy finnish. Cheers Rhowna
Post by JBJ on Sept 24, 2008 15:52:48 GMT 10
hi rhowna,
I'm finding lots of different plywoods are out there, dependent on where you want to buy from.
you havent shown your locality in your ID sign on, so I'm guessing that your probably going to be near a large hardware outlet. you will need to use external quality ply externally.
I live in the bush to a point, like the nearby big towns have a smaller Bunnings in each. Also one of the towns actually has a plywood dealer, who can get various types of ply generally.
I find if I go to the specialised guy I can get a fairly fine grained surface in a flat sheet, but I've got to pay a premium price for the really nice stuff, & pay delivery the 20km to my place.
But I've used the slightly coarser surfaces before, & if you're prepared to put bit of sanding into the undercoats, they end up pretty well looking the same.
Similarly if you need the ply to bend, you need to look around, depending on radius neede & sizes of sheets.
Obviously if you are in more populated areas than I am there will be more choices. but look around as there is an enormous range out there i believe
Post by retro1 on Sept 25, 2008 9:07:42 GMT 10
The best plywood to use is an "A" or better still "AA'grade marine ply. An "AA" has two good faces with no holes or glue lines in the middle layers. You could use "B" or lower grades but the finishes have knots, gum lines etc. The other option is masonite but this is heavier and will not last as long. Cheers retro1
tonyh
"Dolly" 1967 Riviera
Post by tonyh on Sept 27, 2008 18:40:21 GMT 10
Hi Rhowna, The ply I am using to replace my floor is as retro1 said AA marine grade Cheers, tonyh ;D
Post by rhowna on Oct 1, 2008 14:18:44 GMT 10
Thanks everyone for your help, when i finally get started i will use your advice. In case you might be interested im in Albury.
