Post by humpty2 on Aug 25, 2008 19:58:23 GMT 10
What are fellow Olympians lining the back and top of their overhead cupboards with?.................to hide the raw fibreglass. My linings were ripped out and I need to replace them with something, but not sure what to use. Regards Humpty.
Post by atouchofglass on Aug 25, 2008 20:58:48 GMT 10
Hey Humpty2
Mate the stuff I had in the '68 was very thin foam that looked shyt. We needed some type of covering for the back and ceiling of the cupboards that looked good and insulated So I decided to kill two problems with one stone....
Working in air-conditioning gives you access to insulation that normally you wouldn't see..
There is a stuff on the market called Thermo Break"" Comes in various thicknesses with a silver foil front and has a sticky back on it Used inside air handlers to insulate the chilled air against the outside temperature
The 15mm thickness is about the best for my needs and sits behind the walls of the pantry etc ...
Thermo Break is sold in one metre widths and 15mm can be bought in lengths up to 20metres... which is about the amount you need to do all the insulation in a 16 foot Olympic
By cutting 500mm wide strips x the length you need and forcing it into the cupboard it will conform to the shape of the van and go right up over the top into the cavity in the roof... It fits so well that I didn't remove the cover over the sticky backing unless needed
Not cheap at about $25 a metre... To do the overheads it would take about 7- 8 metres.. Will try to get you a photo if you're interested...
Atog
Post by humpty2 on Aug 26, 2008 20:01:28 GMT 10
Thanks for that Atog, the son works in refrigeration so the cost may not be that high I hope. Humpty.
Post by atouchofglass on Aug 26, 2008 20:06:43 GMT 10
Hey Humpty
Trade price was about $23 a metre here in Cairns from A&B Mintec
There is a cheaper version without the sticky backing I am told Perhaps it is a viable alternative
Atog
