Post by shelby007 on Jul 7, 2008 10:31:00 GMT 10
Post by atouchofglass on Jul 8, 2008 18:01:38 GMT 10
shelby007 Nice van A little bit of a tidy up and you're "on the road again" ;D ;D Atog
Post by frankidownunder on Jul 8, 2008 21:41:27 GMT 10
Hi shelby007, Can you get a look at the makers plates on your fridge or stove (usually on the bak of appliance),If they are original they may have a manufacture date on them which would be pretty close to the manufacture date of your van. helped me a lot to date my Franklin reasonably accuratly.
Cheers, Denis.
Post by tinnie on Jul 8, 2008 22:59:15 GMT 10
Hi shelby007, I no nothing about sunliners, however: the light fitting, door handles and hinges look early sixties to me (perhaps 1962-1965?) The wind out windows would have to be retro-fitted as they'd be 1970s, to my knowledge sunliner were out of production well before then.... Cheers, Gristy
Post by shelby007 on Aug 1, 2008 13:24:20 GMT 10
Thank you everyone for your comments. Is there anyone out there with inside fibreglass moulded cupboards like this? Maybe this is the key to finding the right year. The fridge and stove are not original so they were no help.
Post by humpty2 on Aug 1, 2008 20:25:37 GMT 10
To the best of my knowledge, you would have pretty well the last of the Sunliners made about 1966. The fibreglass internal lining is very rare and your hinges on the cupboards are different to most....the external door hinges loook like they are cast ala Olympic. The 'C' section chassis also indicates it's one of the last few made. Have you checked for the chassis number? ....it should be stamped on the top of your chassis rail about 8" back from the coupling, could be either side. It will read yy/mm and then a build number (around about 500/600)
Post by cootoz on Aug 8, 2008 20:13:49 GMT 10
where did you find your beaut sunliner ? Cootoz
