Post by winterwood on Jul 1, 2008 16:57:01 GMT 10
Hi all, After fixing the brakes, bearings and the lights, I'm about to register my '64 Globe Trotter in Victoria. The current S.A. registration sticker quotes a chassis number "2617", however for the life of me, I can't locate it anywhere. Can anyone please direct me where it is ... or where it should be?? Max
Post by greedy53 on Jul 1, 2008 17:39:47 GMT 10
geday my name is steve and for many years i was a trouble shooter for a used van yard and this little problem often popped up the reason especially older vans the number were on the a frame usually welded on using the welder like a texta but over time the a frames were replaced and the number omited you are lucky as you have the numbers if these are on paper work good all you need to do is reweld them on good luck
Post by humpty2 on Jul 1, 2008 18:55:01 GMT 10
Have you checked underneath the A frame? .......like Olympics.
Post by firefighter on Jul 1, 2008 19:50:18 GMT 10
Hi winterwood all you need is a set of number punches & punch the no you have in to the top of 1 of your chassis rails I have a set of punches..... pm us where abouts in melbourne you live .....or go to bunnings and buy a cheap set I done this with my van and vic roads passed it f/f ;D ;D ;D ;D ;D ;D
Post by Daggsey on Jul 1, 2008 20:19:53 GMT 10
Hi winterwood, After registering my 1959 Globetrotter and the WA Transport Dept issuing a new number, I was wirebrushing the drawbar and lo and behold, the chassis no. appeared . It had been stamped with a punch, (just like firefighter said to do) and had been buried under layers of paint. Unfortunately I'm in Qld at the moment and nowhere near the Globe, so I can only advise that from memory, it was on the top of the drawbar, somewhere very near the tow hitch. From memory, it was a four didget number and I'm sure it started with a 2. Daggsey
Post by tinnie on Jul 1, 2008 21:28:48 GMT 10
Hi winterwood, before you drag out the welder or number punches, have a look also on the inner side of the a -frame chassis rails, I found the number on my ol Viscount there. Cheers, Gristy
Post by winterwood on Jul 1, 2008 23:18:47 GMT 10
Thanks to everyone for all your helpful answers/suggestions. Whilst we live in Melbourne, we keep the van stored at our holiday place down at Rye on the Mornington Peninsula and will try out your suggestions on the weekend. Sincere thanks again to all.
Winterwood
Post by minicamper on Jul 2, 2008 7:48:54 GMT 10
Hi Max,
i also have punches and you know where i am, which is closer to the van if you need help, yell.
Cheers Chris
Post by 313royal on Jul 2, 2008 8:31:04 GMT 10
On my 1965 Globie the number is stamped on top of draw bar next to tow coupling
313
Post by Cruz on Jul 2, 2008 10:48:08 GMT 10
Hi, Number on my Globetrotter was also on the drawbar next to coupling it is stamped on both sides .I could not see it until paint was stripped. Cruz
Post by winterwood on Jul 8, 2008 9:20:53 GMT 10
You little beauty, I found the missing chassis number and it was exactly where daggsey, 313royal and cruz said it would be ... including the removal of some layers of paint. Thanks again to all who replied. The number is 2617 as per the current S.A. rego sticker.
I simply would not have found it had it not been for this forum and as a "new chum', I find it a bit sad that there appears to be a bit of discontent and negativity creeping in to a number of posts in recent times. To the more senior "members" , please get together and work "behind the scenes" to sort out any differences before this great forum loses some of its shine. It's a great concept you have, and it should be preserved and maintained just like V V's.
Max
Post by Daggsey on Jul 8, 2008 9:39:36 GMT 10
Hi winterwood,
Great news that you found the chassis number and I'm pleased this forum helped you achieve that.
I apologise to you and all members for my recent rantings which certainly have been off-putting to members, new and old.
Daggsey
tonyh
"Dolly" 1967 Riviera
Post by tonyh on Jul 8, 2008 13:36:57 GMT 10
Hi Daggsey, We have all been there from time to time but there is an old saying I think is a pretty good one "Never judge a man on his worst day" Keep Smiling ;D ;D and please wear some pants in caravan parks ;D ;D Cheers, tonyh
Post by gilbert on Jul 21, 2015 8:45:13 GMT 10
Hi i found some numbers on my Globe on the coupling it says GLOBE 603 then stamped near it it says 561 would that be the chassis number
