Post by minicamper on Jun 10, 2008 9:38:52 GMT 10
Hi Guys, Can anyone help me with window stays? The windows in Skanky van are aluminium that have plastic stays with a cross section like this You open the window and then tighten a wing nut onto the plastic stays. There's also an extension on the bottom that slides over a metal lug on the window to keep the windows shut. Needless to say, all the plastic ones are broken, either in half, or at the mounting point where they rivet onto the window. Can you still get these, or do i need to spend some hours preproducing them out of timber? Cheers Chris
lazza
Post by lazza on Jun 13, 2008 20:00:42 GMT 10
Chris, these stays are a current item available from caravan accessories shops. They are a stay for Alfab windows. They come in 2 lengths and are right and left handed. If you have a problem getting them pm me as we have them in stock. Regards Larry W
Post by minicamper on Jun 14, 2008 8:11:16 GMT 10
Thanks Larry, I'll check out the nearest Caravan place and let you know if i get stuck
Cheers Chris
