donr
Post by donr on Nov 14, 2022 15:31:32 GMT 10
Hi, New to this site. Just picked up this van, it's a coronet 17ft but that is all i know. Tried googling it but could not find the exact pic. Does anyone have an idea of model and year? Attachments:
Post by jenwhe on Nov 14, 2022 15:37:30 GMT 10
Hi, New to this site. Just picked up this van, it's a coronet 17ft but that is all i know. Tried googling it but could not find the exact pic. Does anyone have an idea of model and year? The vin on the A frame indicates a code for the year.
Post by jenwhe on Nov 14, 2022 15:40:11 GMT 10
Hi, New to this site. Just picked up this van, it's a coronet 17ft but that is all i know. Tried googling it but could not find the exact pic. Does anyone have an idea of model and year? The vin on the A frame indicates a code for the year. As I picked up a triaxle 77 model; and that’s what I ended up with, without going into Historical rego search of number yet; as apparently that’s all they had back in the early days.
donr
Post by donr on Nov 14, 2022 15:53:13 GMT 10
There is no plate on the frame to indicate the vin.
Post by jenwhe on Nov 14, 2022 16:17:54 GMT 10
There is no plate on the frame to indicate the vin. It won’t have a plate, they are welded on, have a look under all around A frame
Post by hughdeany on Nov 14, 2022 16:40:57 GMT 10
Hi jenwhe, It doesn’t have a vin number,they came out in 1989,it will have a chassis number, Your van is a 15x7 Coronet about 1965 model. If you look in the down history lane section under Coronet you will find an identical van to compare it to. Cheers hughdeany
donr
Post by donr on Nov 14, 2022 17:18:17 GMT 10
Thanks hughdeany, I found what could be a chassis number created with a welder on the frame but very worn and difficult to read because of the rust. I also found a pic in the down history lane that looked identical, a 1962 model. cheers Don
Post by jenwhe on Nov 14, 2022 20:32:23 GMT 10
Thanks hughdeany, I found what could be a chassis number created with a welder on the frame but very worn and difficult to read because of the rust. I also found a pic in the down history lane that looked identical, a 1962 model. cheers Don Congratulations…..
Post by jenwhe on Nov 14, 2022 20:34:50 GMT 10
Hi jenwhe, It doesn’t have a vin number,they came out in 1989,it will have a chassis number, Your van is a 15x7 Coronet about 1965 model. If you look in the down history lane section under Coronet you will find an identical van to compare it to. Cheers hughdeany That’s what I meant, it’s an implement.👍
