Post by Mustang on Jun 1, 2022 7:47:10 GMT 10
A LONG SHOT:Some time back 2021 there was a post about stick on window seal for push out caravan windows . The seal approx 12x 5 mm was on a roll ,sticky on one side, it was reputed not to compress like foam.Our windows have an internal frame & the seal is required to fit "inside" the frame. I believe the supplier is from Cairns /Townsville area ? I filed the details away for future use , never to be seen again !!!!! Mustang PS I have searched here for a couple of hours before posting.
Post by aussieute on Jun 1, 2022 9:42:45 GMT 10
Hi Mustang swift supply's in Beenleigh Qld list as having different sizes 07 31808824 and I think it was Jenkins rubber Cairns hope this helps cheers Chris
Post by Surf Tragic on Jun 1, 2022 16:52:06 GMT 10
it was Jenkins Rubber in Cairns this is sticky back felt, & very good. Cheers. Surf Tragic 61 by Surf Tragic, on Flickr
Post by Mustang on Jun 2, 2022 11:23:42 GMT 10
Hi assieute & Surf Tragic, Thats the one, I've made a hard copy this time !!! Cheers Mustang
PS Ordered as well.
Post by shesgotthelook on Jun 2, 2022 20:42:01 GMT 10
Hi Mustang, do you know how to bookmark threads? A good thing for future references. I have used this type of rubber but found it needed a bit of extra adhesive to stay stuck. Cheers, SGTL Attachments:
Post by Mustang on Jun 3, 2022 7:21:37 GMT 10
Hi Mustang, do you know how to bookmark threads? A good thing for future references. I have used this type of rubber but found it needed a bit of extra adhesive to stay stuck. Cheers, SGTL Thank you for the tip, I didn't know about the bookmark. We were caught out in the recent SE Qld torrential rain event, only a small amount of water was forced in between the front frames. Probably we won't experience that again, while towing. Cheers
