nic
Brakes
Mar 28, 2022 14:49:38 GMT 10
via mobile
Post by nic on Mar 28, 2022 14:49:38 GMT 10
Hi, I have just replaced hydraulic cylinder on Franklin Arrow about 70ish Released the bleeder valve on the hub, but can’t get the fluid to pump thru. Any help would be greatly appreciated. Nic.
Brakes
Mar 28, 2022 16:10:36 GMT 10
Post by Geoff & Jude on Mar 28, 2022 16:10:36 GMT 10
hi nic
if they haven't been used for a long while, quite often the bleeder valves corrode and the hole becomes blocked - this can happen at either end of the bleeder valve.
remove them and clean them out if necessary or better still, replace them with new ones.
Brakes
Mar 29, 2022 15:40:53 GMT 10
Post by thegeneral on Mar 29, 2022 15:40:53 GMT 10
the flex hose from chassis to axell over time can block, or you need to start at the front and check and clean as you go. Graeme
nic
Post by nic on Mar 30, 2022 9:07:47 GMT 10
Thanks guys for the response. Followed your advice with great success. Many thanks Nic.
