Post by brett930 on Sept 26, 2021 21:39:56 GMT 10
Can anyone tell me what type of wheels would likely have been fitted in 1966 to my 15'2" Baravan Safari?
They're 13 inch, 5 stud.
Post by Mustang on Sept 27, 2021 8:52:18 GMT 10
I would think Holden? see this link
Post by brett930 on Sept 27, 2021 9:10:29 GMT 10
I would think Holden? see this linkThanks.. I figured they might be, but is there any particular model/s that they match? Based on the link, I clearly didn't measure the hole distance correctly (so will re-do this) but they appear to be in the 107mm region. I need to source one more wheel (for a spare) assuming the ones I have clean up ok, so want to make sure I get the same. PXL_20210918_010710808 by Baravan#930, on Flickr PXL_20210918_010649482 by Baravan#930, on Flickr
Post by Rattles on Sept 27, 2021 12:25:49 GMT 10
Before HD - HD + the triangle between the Stud Holes are Higher and Narrower. Rattles
Post by brett930 on Sept 27, 2021 12:58:36 GMT 10
Before HD - HD + the triangle between the Stud Holes are Higher and Narrower. Rattles That makes sense... The van is a 1966 model, the HD was introduced in '65, but I presume that Baravan wouldn't be using wheels off the latest model. The EH came out in '63, so these wheels would have been available for a while by the time my van was built.
Post by Rattles on Sept 28, 2021 9:34:50 GMT 10
And from memory the rim offset also changed for the HD + . Rattles
leeron
1966 Viscount Duralvan 14' 6
Post by leeron on Oct 1, 2021 18:10:58 GMT 10
You can see it also takes the wide angle wheel nuts... Are you keeping them or looking to go to rims that have a bead so you can go tubeless?
