Post by silverslug on Jul 10, 2021 17:34:42 GMT 10
Hi everyone We have recently acquired a 1958 sunliner. We love her but the front fixed curved windows are leaking quite badly. I am thinking of pulling windows out and redoing seals etc because the extra sealing we have tried has not worked. The windows are currently 4.5mm Perspex. Does anyone know the best rubber seals to use and have any tricks/advice on how to pull this project off?
Post by Mustang on Jul 23, 2021 12:43:50 GMT 10
Good Friends "Bluebird" put us onto a rubber that might suit the Sunliner "Fixed" windows. It is from Windscreens O'Brian & the part number is 520076. The rubber turns the radius beautifully without puckering, the stiffener strip is attached & one side of the flap is generous which allows fitting without special tools. We fitted one side with cord & one without, its neater to fit the rubber to the caravan frame then insert the window to the rubber. I used poly Acrycast 3mm instead of glass.
