Post by Deleted on Mar 25, 2008 10:48:13 GMT 10
Hi there,
I am ordering new hubs / axle etc for my caravan and I think I may have hit a snag, I want to run the standard fb holden wheels with caps / white walls etc. The stud pattern is the same but I have had a look and the centre bores are different. fb has a 63.4ml and hk/t/g has 64.3. So I think that when I go to put the wheels on the centre bore will be about 1mm to small on the wheel and foul. I am getting a cable operated disc brake set up for it, hopefully the trailer hub is all flat with 5 studs poking through and doesn't have a centre in it which is 64.3 ml round.
I have seen quite alot of other people run the early style holden wheels on their vans, so I thought I would ask and see how it works.
Thanks in advance
Andrew
Post by Deleted on Mar 31, 2008 16:18:01 GMT 10
Hi again,
If anybody cares I took a standard holden wheel to the trailer place which is supplying me with all the bits and tried a ht hub on it and it fit no probs.
Cheers
Post by vintagecaravans on Mar 31, 2008 16:35:16 GMT 10
Andrew PM Sent
