Post by tinnie on Jan 15, 2008 0:19:43 GMT 10
Hi, can any of you engineering genius VVers suggest ideas of how to strengthen the draw bar ('a' frame) on my Franklin. It is fairly light angle (original I am quite certain) and I have noticed a fair bit of flex in it (more than I am happy with for the treck to the mount). I had thought of making a new drawbar as the existing one is short but I would prefer to try to retain the originality (it has the old "763" build number on it). I had thought of welding a bar through the middle (box tube perhaps) from back near the axle through to the coupling. I would appreciate any other suggestions, as I'm not generally one for playing with steel. Cheers, Gristy
Post by Roehm3108 on Jan 16, 2008 17:15:59 GMT 10
What you say makes sense, Would have thought that the gas bottle holder framing would have helped too. But, to be sure, I would talk to a mechanical engineer who know about such stresses. Stresses are strange things to a layman. Wanted to have my house turned 90 degrees by a crane, until the crane fellow explained the stresses involved. Put me off doing anything like that forever - not impossible, but would have cost a fortune. Not saying a van is the same, just that it pays sometimes to get the right advice. Some things are just not worth guesstimating. Cheers Ray
Post by tinnie on Jan 16, 2008 20:42:15 GMT 10
Thanks Ray, Good advice, I am definately not going to take chances. I have seen the damage that can be done by simply jacking up a house to reblock it. Most likely the fact that the van has been this way for forty five years it could be fine, but I think that the flexing produces a rebound effect with every decent bump it hits, making the van bounce more. Now 45 years ago, travelling at 45-50mph that may have been okay, but I ( unfortunately )tow with a modern car, capable of hauling a van comfortably at double that speed (not that I would!). So in addition to being safer, I think that strengthening the drawbar/chassis will probably make it sit better on the road too. Fortunately I do know of a couple of engineers.... Really trying to weigh up whether to replace the a frame or try to strengthen it in some way & retain the originality. Cheers, Gristy
Post by hwyman on Jan 16, 2008 20:44:52 GMT 10
Hey Gristy i guess you only have a single piece of angle on each side if that's the case what i would do is run some thicker angle 4or5mm under each side so it becomes a box section instead of angle. if you buy it a little wider you can run your weld's where it over hangs at the top and bottom (much easier) i would only weld it at about every 200mm with weld's being about 25mm long.
Hwyman.
Post by tinnie on Jan 18, 2008 20:46:56 GMT 10
Thanks hwyman. You are right about the angle and your advice would add considerable strength. That is sounding like the solution to me! Cheers, Gristy
