Post by boatstobuild84 on Jan 29, 2019 22:09:18 GMT 10
I’m trying to do up a knackered 1983 sprite for little family holidays. I have managed to tackle top leaks by removing and sealing awning rail but it seams water is running down front the under and soaking thru the floor battens! I have no idea if this was just dealt with by painting the underside of batten or am I missing a trim or something. Any help much appreciated as I am totally clueless and this caravan has been mucked around with loads! Will try and get photo of the issue.
Post by Mustang on Jan 30, 2019 7:58:14 GMT 10
I’m trying to do up a knackered 1983 sprite for little family holidays. I have managed to tackle top leaks by removing and sealing awning rail but it seams water is running down front the under and soaking thru the floor battens! I have no idea if this was just dealt with by painting the underside of batten or am I missing a trim or something. Any help much appreciated as I am totally clueless and this caravan has been mucked around with loads! Will try and get photo of the issue. Hi BB, You really need pics here as the problem is too broad to just try & describe. Cheers Brent
Post by Don Ricardo on Jan 30, 2019 15:04:38 GMT 10
Hi Boatstobuild84,
Welcome to the forum.
You mention that you have a Sprite. Does that mean you're based in New Zealand or the UK? I was just wondering because Sprites weren't sold in Australia, but a small number may have been imported here. It doesn't matter where you're located though - we will provide some advice if we can.
There are instructions on how to post photos on the forum in the 'Forum Guidelines & Helpful Hints' section. Feel free to call out if you have any problems with the instructions.
