Post by aussieute on Jun 21, 2018 17:22:18 GMT 10
photo sharing websitesI need several light fittings that you can adjust with the on off switch as per photos not sure how many I need yet I think 6 thanks chris
Post by aussieute on Jul 16, 2018 10:37:19 GMT 10
Still looking for some
Post by Gypsy 10 on Jul 16, 2018 21:43:34 GMT 10
Post by aussieute on Jul 17, 2018 14:39:35 GMT 10
Mine have the switch built in to the lamp holder you can see the black switch just I have found that kind but hoping to get original so don't have to wire in switch thanks chris
Post by Rattles on Jul 18, 2018 10:47:04 GMT 10
The old Fittings you have may be a bit suspect due to their age. If you get new fittings and Mount a Architrave Switch (see image Below) and if needed a mounting block (see image 2 below) The existing wiring would be long enough and easy job to run wires between switch and adjustable batten holder. Example of switch: And if needed: Just another way over the supply problem. Rattles
