Post by Don Ricardo on Jul 9, 2007 23:54:11 GMT 10
Hi everyone,
Now here’s a bit of a puzzle to interest all of you Don restorers and amateur (or professional) auto electrician’s out there.
One of the items of optional equipment listed in the sales brochure for late 1940’s Dons was a “Radio (latest vibrator sets)”. Then in the ‘General Specifications’ section, under the heading ‘Electrical’, the brochure says:
“Battery, aerial, and earth leads wired to radio shelf, with 50 feet of aerial wire built into roof. (All models except ‘Utility’).” [The ‘Utility’ model was the 12 ft 121 model.]
Intrigued with these comments I went on a voyage of discovery in our van, and concluded that the ‘radio shelf’ in the 14 ft vans is the shelf located above the divan at the rear of the van:
Just above the shelf appear to be the ‘battery, aerial, and earth leads’, or at least the connecting point for some or all of them:
So here are some questions:
1. Am I correct in assuming that the visible wires above the shelf are indeed the connection points?
2. Do the three wires correspond to the ‘battery, aerial, and earth leads’, and how would you work out which ones are which?
3. If an owner purchased an optional radio would there have been some sort of a socket attached to the wires to which the radio would be plugged in, or would the radio have been permanently wired in?
4. Where is the ‘radio shelf’ in the 12 ft and 10 ft Don models?
5. Has anyone who has worked on the roof of their Don seen signs of the aerial wires mentioned? (50 ft of wiring is a heck of a lot of wire – 15 metres!!)
6. What is a “radio (latest vibrator sets)”? (I thought that vibration mode was only introduced with mobile phones set on silent! ;D)
7. Were in-built radio connection points common or optional in other makes of caravans in the 40’s and 50’s?
And most importantly of all:
8. Is there anybody with a Don caravan who has one of the optional radios and/or the connection point all ready set up to use? If so I’m sure we would all love to see some photos!
I am interested in any info or thoughts people might have on all of this.
Regards,
Regards,
