Post by kerri on Jan 2, 2017 14:41:53 GMT 10
tonyh
"Dolly" 1967 Riviera
Post by tonyh on Feb 15, 2017 19:42:22 GMT 10
Hi Kerri, The main rubber that seals against the body looks like the rubber I have in stock, so give me a ring on 0431 399 266, Cheers, Tony
Post by woody76 on Apr 17, 2017 20:08:57 GMT 10
Hey Kerri when you get your new rubber use baby oil to slide it in, as with type of window soap will take forever like 4hrs . Baby oil will make it a 20 min job And in the first pic you can see the frame is pushed on to the rubber.Open this up as it locks the rubber in and then lock back on when in. I hope you find the window seal as I found it a bit hard Good luck Cheers Chris
tonyh
Post by tonyh on Apr 23, 2017 23:05:58 GMT 10
Hi Kerri, are you still looking for the rubber? I have it in stock so give me a call 0431 399 266, Cheers TonyH
Post by kerri on Jun 11, 2017 19:24:53 GMT 10
Hi Tony, Can I give you a call tomorrow to chat about the window rubbers? Can you send a photo of what you have? Thanks Kerri
Post by kerri on Jun 11, 2017 19:25:48 GMT 10
Hey Kerri when you get your new rubber use baby oil to slide it in, as with type of window soap will take forever like 4hrs . Baby oil will make it a 20 min job And in the first pic you can see the frame is pushed on to the rubber.Open this up as it locks the rubber in and then lock back on when in. I hope you find the window seal as I found it a bit hard Good luck Cheers Chris Hi, I will be trying to pull apart my first window tomorrow. I have a copy of the tutorial you posted and will let you know how I go. Thanks Kerri
Post by pu2nule2 on Jun 15, 2017 6:52:51 GMT 10
where about are you located ? I have just replaced all my windows with polycarbonate ,and new rubber, relatively easy job once you have done the first one ,have a few hints if you haven't done them yet.............................................bob
Post by kerri on Jun 17, 2017 11:05:29 GMT 10
Post by kerri on Sept 11, 2017 7:54:44 GMT 10
