gtick
Post by gtick on Mar 4, 2016 9:31:57 GMT 10
Hi all, I have these 2 window parts that need to be replaced on all Windows (as you can see by their state) I know what they are called and have found somewhere to buy the exact parts (although we require 14 of each so it works out quite pricey), but I was wondering if anyone has replaced these parts with anything different? As i'm new to the world of vintage caravans, I'm not sure whether it is better to replace these old parts with something identical (for the sake of function and keeping to the vintage look and feel) or whether I could replace them with something more subtle and "aesthetically pleasing"? Suggestions perhaps? Cheers G
Post by shesgotthelook on Mar 4, 2016 10:08:13 GMT 10
Post by JBJ on Mar 4, 2016 10:41:01 GMT 10
Hi
I have about 6 or so of the retaining clip assemblies new, that I over ordered. They are the long ones, & I paid about $10 each.
If you want I can take a photo of them, & check on postage costs I will sell them to anyone for $7.50 each plus plus postage. I will need your post code to work out out postage.
Otherwise these bits & heaps of others will be on our for sale table at the nationals. JBJ
gtick
Post by gtick on Mar 5, 2016 10:51:08 GMT 10
Thanks for the suggestions people. I have just bit the bullet and gone ahead and purchased the exact replacement parts which appeared cheaper than most were suggesting anyway so figured I needed to adjust my expectation of costs!! ....In addition I finally have the Windows off and we can see clearly what rubbers we need. I have contacted the recommendations from here already with no success so if anyone else might be able to assist me in finding these seals I would be much appreciative! (Incidently our local glass place won't even give me a quote on replacing the glass on the 3 broken windows until we have the rubber seals which is SUPER helpful :/ )
Post by Rodnet on Mar 5, 2016 18:17:21 GMT 10
All of the window fittings that you are after are available at your local caravan dealer, or at least they are here in Coffs Harbour. Sometimes parts for vintage vans are not as hard to obtain as people may think. Always a good starting point (not always successful though) is your local caravan dealer Good luck Rod
gtick
Post by gtick on Mar 5, 2016 21:47:07 GMT 10
All of the window fittings that you are after are available at your local caravan dealer, or at least they are here in Coffs Harbour. Sometimes parts for vintage vans are not as hard to obtain as people may think. Always a good starting point (not always successful though) is your local caravan dealer Good luck Rod Thanks Rodnet, I appreciate that may be the case but I live on an Island and don't have a "local caravan dealer" to check so am trying to source things online where possible (which is made more challenging when you have no idea what things are actually called) I have since purchased the metal clips shown, but can not find anywhere to get replacement rubber window seals and It was suggested to me to try posting on this forum and that someone here may be able to help me. If you think you have a local place that can supply these window seals, a name and contact details for them would be hugely appreciated. Thanks
Post by Rodnet on Mar 6, 2016 12:26:11 GMT 10
Yeah, sorry mate, I knew and then promptly forgot about the island thing. Must make it tough for you.. Did you manage to get any of the stays? If you haven't then I can get you some, stick 'em in a postage bag and sent them across. You stick some money in my bank and all is done. Just let me know. Rubber, a bit harder without physical sample in my hand, maybe email to Clarkes Rubber or a rubber specialist for vintage cars. They seem to have a squillion and 1 profiles
Cheers
gtick
Post by gtick on Mar 6, 2016 15:25:05 GMT 10
Thanks for the offer Rodnet. Yeah I just ended up buying the same stays and swing bolt as the originals from an online store. The rubbers are certainly proving to be a bit tricky so will keep working on that one. Yes the Island thing is a bit tricky with a lot of things....in particular sourcing products! Ahhhh good times Thx G
