Post by patrick on May 22, 2015 11:54:01 GMT 10
Hi All,
As per the title I'm after a complete front window with frame. Seals etc to suit my 64 Sunliner.
Current one was replaced with an air con unit before I bought her.
I'm on the South side of Sydney but happy to collect within reason or courier.
Thanks, Patrick.
Post by patrick on Jun 9, 2015 19:50:30 GMT 10
Nobody? Anyone know a wrecker that might have this stuff in NSW?
Cheers, Patrick.
Post by JBJ on Jun 9, 2015 20:58:38 GMT 10
Hi
Sunliners didnt have window frames at front or rear. They had perspex fixed panels, moulded to shape, & held in with rubbers. if you have one with a window frame, its either modified by someone, or possibly a Gracemure queensland built. It would be easier for us to tell if you posted some pictures. Not many of us are mind readers, & dont really know what you are looking for unless you show us.
But there are heaps of photos of sunliners on here. If you cant post a photo, why not look thru old photos on here, & tell us which one its the same as
Then you may find someone can help you
JBJ.
Post by Don Ricardo on Jun 9, 2015 21:55:39 GMT 10
Hi JBJ and Patrick, If Patrick's Sunliner has a type 3 body (1963+) - as it appears to have from his photo here - it will have opening aluminium framed front windows. Not sure what the window hinges off though - presumably it is attached to a metal frame? Patrick - it may take you a while to find a window. Someone may have one lying around if they have pulled a Sunliner apart. Trouble is Sunliners seem to last, being made of fibreglass, and being a popular type of vintage caravan tend to be rebuilt rather than wrecked! You may need to take some measurements and see if you can find an alternative that you can adapt. Don Ricardo
Post by patrick on Jun 22, 2015 13:27:54 GMT 10
Hi JBJ / Don, Sorry for the late reply. I don't get on here too often. Thanks for the info. My vans a 64 so has the opening front windows like this. You can also see the offensive AC unit pretty clearly. The frames are qualicraft - see close ups below. Measurements are approximately 77.5cm wide by 46 high so slightly different to the side ones. Is there a record somewhere of Qualicraft sizes by van as I'm hoping there fitted to something else? If not do you have any other suggestions? Thanks in advance, Patrick.
Post by Don Ricardo on Jun 22, 2015 17:31:32 GMT 10
G'day Patrick,
Good to hear from you again.
You'd have to think (or at least like to think) that Sunliner used one of Qualcraft's standard sized windows. Hopefully, someone on the forum will be able to help you out.
If you don't hear from anyone for a while, give your post a bump every now and then by clicking on the Quote button.
Post by patrick on Jan 17, 2016 12:51:15 GMT 10
Hi All,
Just bumping this one up.
I'd even consider cutting and welding a larger window frame if anyone has one from another van from the same era.
Thanks, Patrick
raycycled
Rebuild it, reuse it, enjoy it!
Post by raycycled on Jan 23, 2016 6:34:07 GMT 10
Hi Patrick , I have the similar problem with our 60 Sunliner missing 2 side windows, dad has found a place in Adelaide that can make a curved bottom Aluminium window, I live in Sydney, Ray 0408219663
TroyB
Post by TroyB on Apr 15, 2016 22:54:38 GMT 10
hey there. I happen to have a couple front windows. what would they be worth to you? I would prefer to find two side windows to complete my set but after doing a search am thinking my chances are slim to none. I am located on the sunshine coast QLD I also have two have two side windows
Post by yve on May 3, 2016 14:03:45 GMT 10
Hi Troy. Do you still have a Sunliner front window available? As we would be interested in one for our Van. Cheers
bezza
Post by bezza on May 3, 2016 18:56:22 GMT 10
bezza
Post by bezza on May 3, 2016 19:05:40 GMT 10
Hi troyb I would be interested in the other front window if still available. I am also in Newcastle. I can arrange Cheers Wayne.
bezza
Post by bezza on May 3, 2016 19:07:20 GMT 10
Arrange pick up.
Post by yve on May 4, 2016 18:07:46 GMT 10
In case we can obtain a window from you Troy, we are in Melbourne and happily pay freight.
Post by kelshouse on May 20, 2016 13:08:15 GMT 10
Hi Troy,
I also would be interested if you still have any windows available from your sunliner.
Regards Michael
Post by Mustang on May 20, 2016 16:59:39 GMT 10
You could try this outfit, they are building new Sunliners from an original mold , they must be sourcing frames & windows. link
Post by greedy53 on May 20, 2016 20:00:08 GMT 10
they look a lot like a early viscount
Post by kelshouse on May 20, 2016 22:59:56 GMT 10
Thanks Mustang, they (suncoast sunnies) use current camec windows which apparently are a similar size but look quite different with windsers and fly screen internal frame
