Post by rare00 on Jul 10, 2014 21:01:52 GMT 10
Dulux "all in one" primer/sealer/under coat works very well, ive used two coats on my vans (With a light sand back in between coats)
Then the Dulux top coat on top of that.
Dulux claim you can use their top coat as a primmer etc, but my personal preference is to have both under coat and top coat.
Dulux is a bit more expensive than the other brands, you get what you pay for.
Next will be a debate on oil or water based paint.
One of my vans was done in oil base with a stripe down the side done in water base. It was as clear as a bell after heat gunning the paint off the van the damage the water based paint (The stripe section ) had done to the ply where the oil based sections were in excellent condition.
Good luck sorting through the maze of information on the pro's and cons on oil V water base paints.
