Post by humpty2 on May 16, 2014 15:11:34 GMT 10
Having a yard clean-up, and have decided that I don't have the time to go ahead with this one. Still got 3 full size vans to go!! The chassis has been cut down from a 16' Sapphire caravan from the late 50's. Has Holden 13" wheels on cable operated brakes. Dimensions (now) 1450mm wide.....3300mm long.....tip to tip on the axle is 1900mm with a 2" drop.I have left the draw-bar on to make moving it easy Good value for $100....you pick-up. Janorma is still for sale......$8500 takes it away!!
Post by shesgotthelook on May 16, 2014 16:20:14 GMT 10
No wonder you've still got Janorma, $85,000!
Post by winterwood on May 16, 2014 17:38:16 GMT 10
SGTL,
I think you may have added an extra "nought" to the sale price
Max
Post by humpty2 on May 16, 2014 18:22:36 GMT 10
Did & still reads $8500....note there is no editing on the post.
Post by Deleted on May 16, 2014 19:25:15 GMT 10
Having a yard clean-up, and have decided that I don't have the time to go ahead with this one. Still got 3 full size vans to go!! The chassis has been cut down from a 16' Sapphire caravan from the late 50's. Has Holden 13" wheels on cable operated brakes. Dimensions (now) 1450mm wide.....3300mm long.....tip to tip on the axle is 1900mm with a 2" drop.I have left the draw-bar on to make moving it easy Good value for $100....you pick-up. Janorma is still for sale......$8500 takes it away!! Anyone with even half a notion about building a Teardrop should jump straight on this... Its cheap and will save you a LOT of time and money on a teardrop build...umm that's if you don't mind finishing up with a replica !!! Hmmmmmmmmmm...tempted ... I dunno wether I have another teardrop build left in me Humpty2 Reddo
Post by shesgotthelook on May 16, 2014 19:32:45 GMT 10
Shute, maybe I should wear my glasses more often. I double checked before I posted & was sure it said 85000
Post by firefighter on May 16, 2014 19:50:48 GMT 10
I think a few members need to wear glasses or go and have an eye test ....it was edited from $85000 down to $8500 and it shows the post was edited
cheers f/f
Post by humpty2 on May 16, 2014 20:31:54 GMT 10
But not by me.....thanks F/F........but 85000 would be nice Re a tear-drop replica......the chassis is late 50's maybe a 60
Post by Deleted on May 16, 2014 20:39:08 GMT 10
Perhaps the $85,000 may have been for the ENTIRE yard clean up...... not just the Janorma Reddo
