Post by scootman on May 10, 2014 13:54:32 GMT 10
Hi All. Yep been a very long time since I posted but I lurk regularly. for the firts time in three years (Think canungra was the last time) Im going to take princess Helen out for a weekend. Sadly she has suffered a bit from lack of use and theres been a bit of repair work going on. What I would like to know is how to polish the aluminium sheet at the front of the van? Any idea out there? cheers Owen AKA Scoot
Post by akeepsake on May 10, 2014 15:50:30 GMT 10
Giday Scoot ! Get a bottle of purple polish from any car or truck suppliers and some deoxidiser if it's really bad! Follow instructions on the bottle ! Be sure to have a big breakfast before " wax on, wax off" you'll need it! If you have a buffer all the better but still eat the big breakky ! Cheers Andrew
Post by scootman on May 10, 2014 16:16:03 GMT 10
MMMM thanks Andrew will give it a shot
Post by onesneverenough on May 16, 2014 7:53:50 GMT 10
Hi Scoot
i have been polishing the cladding on the 1967 Franklin which has the textured diamond pattern.
First i have been using a mid grade steel wool to clean out the grooves.
For polishing I have tried a few brands but among them all Autosol which i bought in a large tin for $54 would do my 20' several times over at least. Using a lambs wool buff on very slow speed, initially it will go black. With some of the more expensive products some water from a squirt bottle was needed to help it spread but the Autosol seems to not need any water.
When i initially started i proceeded very gingerly not wanting to buff off the pattern. I'v never used a buff before. However i found that it is possible to lay into it quite a bit and not hurt the pattern.
after it goes black move forward and let the initial area dry a bit and keeping moving eventually it will begin to brighten u beautifully.
Finally if you want a mirror finish i was also pointed to a Meguiars swirl remover which is a very fine grade polish and with a new mop on it did give a slightly better finish and on flat sheet would certainly give a lift. I didn't think if made enough difference to the patterned sheets but I think i will give it a quick once over once the claddings all back on to give it a neater more consistant appearance.
I have heard many raving about Purple polish but could not find any, an Autobarn said they 'had heard of it' however I am very happy with the Autosol.
Best of luck
Post by Roehm3108 on May 16, 2014 8:03:02 GMT 10
Sadly she has suffered a bit from lack of use and theres been a bit of repair work going on. Hey Scoot. Good to hear you're still lurking! You have given a great lesson in your comment, that should be noted by ALL vintage vanners - USE IT OR LOSE IT. Ya gotta look after them babies
Post by mibosa on May 26, 2014 16:33:06 GMT 10
Hi guys, where can I get the large tin of Autosol???
Regards, Bob
Post by greedy53 on May 26, 2014 17:44:55 GMT 10
when i drove big rigs i used brasso with a dash of kero take about 40 mm out of brasso and add kero polish eather with a rag or polisher and wipe clean works great and fast
Post by onesneverenough on May 26, 2014 20:50:16 GMT 10
Hi Bob
I purchased mine from Paintmobile Dandenong, Victoria and it cost $54
Gregor
