Post by gabby2013 on Feb 11, 2014 15:40:30 GMT 10
Hi Everyone I am seeking the impossible, or perhaps the highly improbable but I am hopeful! I have a 1962 Sunliner caravan that is missing an original opening side window Width 65cm, Height 46.5cm I am not able to upload images to the forum but if you copy and paste the link below into your browser, you can see the van from the side view imgur.com/2pem2MsI look forward to hearing from some of you who have bravely trod before me into Sunliner restoration. Gabby
case
Post by case on Feb 12, 2014 9:42:04 GMT 10
Hi Gabby, There may be another way out.Are your windows the type that have the rubber seal against the body? because I have 3 windows available that use an aluminium frame that is screwed to the body with the sashes sealing against the frames.If you could maybe use a pair of these front or back of the van it would not be too different. The size is now 765 wide x 610 high body opening. The height can easely be made to your 465. They would be 115 wider though. There is a choice of glass or perspex that I have. You can contact me via the forum or ring me on 03-9796-8595 Regards Case.
Post by gabby2013 on Feb 14, 2014 15:38:26 GMT 10
Hi Case Thanks so much for getting back to me. I reckon, for now, we are going to continue the search for an original window (apparently I have a 1 in infinity chance of finding one) that won't need any modifications. However, that being said, I will definitely keep your suggestion in mind in case we fail in our search. thanks again Gabby
