bigkel
Post by bigkel on Jul 11, 2013 18:20:05 GMT 10
raym
Post by raym on Jul 11, 2013 23:31:45 GMT 10
Hi bigkel The springs have most likely rusted and the leaves are stuck together they may free up after a few ks or they could be sagged .Try letting the air out of the tyres this may give you enough room to get the wheel out or try a small jack between the spring and the chassis put a block of wood along chassis so as not to damage it and do not use to much pressure ray
raym
Post by raym on Jul 11, 2013 23:36:09 GMT 10
forgot to add wheels look like they are 16 inch from a vehicle with four letter f word name ray
bigkel
Post by bigkel on Jul 12, 2013 0:16:01 GMT 10
Thanks for that ,, the wheels are 16 inch , letting down the tyre will not help at this stage as the wheel rim will not make it past the brake drum ,, van has been towed recently and springs are not locked up . , jacking the springs down sounds like a good idea ,, thanks
kel.
Post by mandkscarapark on Jul 12, 2013 19:25:32 GMT 10
our toaster 16-2 has 16" 6 stud chev wheels, if i jack up the chassis, not the axle, pull the bottom of the wheel out first the can be removed ok.
Post by mandkscarapark on Jul 12, 2013 19:29:09 GMT 10
it's me again, what's the story on towing dolly ?? in the top picture ? Looks like your brakes are vacuum boosted, huh ? p.s. I really like caraparks.
bigkel
Post by bigkel on Jul 13, 2013 0:20:40 GMT 10
Brakes are both vacume and hydraulic ? have not worked out how or why yet , ,, i did jack up van by chassis , no go , .. this van was towed by a small car in the 60,s ,it must have not been able to take the weight on the tow bar , so they used a tow dolly . cheers kel.
