desmo
Post by desmo on Jul 6, 2013 9:55:34 GMT 10
Good morning all I have decided to take the plunge and build a 10' bondwood van probably along the lines of the wanderer with a single settee up the front and dropped floor, I have a question for all you people with a bit more knowledge than myself on building the chassis what would you use c section ,rhs or a combination of both rhs for the axle carriers and c section for the other not so load bearing components and also what thickness would you use 3mm , 5mm or 6mm keeping in mind weight is a big factor for me as I will be towing it with an Austin a40 all your answers would be appreciated cheers Bo
desmo
Post by desmo on Jul 6, 2013 10:17:47 GMT 10
I should have mentioned this is not a total new van as I have a donour van here that I am going to use keeping within the guidelines of this forum, the chassis that I have here is pretty bad and cannot get a good reference off it al handles latches cupbords etc will be used in the rebuild
cheers Bo
Post by cobber on Jul 6, 2013 13:57:41 GMT 10
G day Desmo, You're going to build something along the lines of the Wanderer. Which Wanderer do you have in mind..... this one . Or this one OR THIS ONE Or is there another one you have in mind ?... the advice you get will depend on which one it is Cobber.
Post by kaybee on Jul 6, 2013 15:02:05 GMT 10
Good morning all I have decided to take the plunge and build a 10' bondwood van probably along the lines of the wanderer with a single settee up the front and dropped floor, I have a question for all you people with a bit more knowledge than myself on building the chassis what would you use c section ,rhs or a combination of both rhs for the axle carriers and c section for the other not so load bearing components and also what thickness would you use 3mm , 5mm or 6mm keeping in mind weight is a big factor for me as I will be towing it with an Austin a40 all your answers would be appreciated cheers Bo G'day Bo , it's good to see someone prepared to make an effort instead of buying "ready made cuties"..... ;D.....here's a pic that might help you with your choice of chassis materials.... ....it's a frame I did for one of our old vans. It's built from 50mm rhs ( box section for the uninitiated) and is a simple perimeter frame and integral drawbar with mounting points for the springs and a couple of crossmembers in the middle to support a water tank ( and the floor of course). This one is out of 3mm wall , but if you're concerned about weight then you can get a lighter section again, from memory about 2.5mm . I favour rhs over angle or C section as it has greater load capacity and far greater rigidity than equivalent size channel or angle which will twist in service quite easily. It also gives you 2 flat sides to work with so welding on mounts, etc is easier and cleaner than working and welding into a corner. Good luck with the project, Colin.
desmo
Post by desmo on Jul 6, 2013 21:19:20 GMT 10
Gday cobber,that sounds very Australian heh it would be the second one but in ten foot form , and kaybee,colin thanks for your reply mate that does help as my design is a gross overkill compared to your piccy but I think rhs is the go will keep you posted on the progress as I said before weight is a factor as I will be towing it with my a40 convertible morris major 1622 b series motor with a Datsun 1000 diff as the final drive which is 3.9
