aquamum
Post by aquamum on Jun 24, 2013 22:16:35 GMT 10
My middle son Chris & I fabricated & welded a new "clamp" to hold my cute little 4kg gas bottle to the front of my Gypsy caravan before I went away earlier this month for a week of caravanning by the beaches of the NSW mid coast.
One night at Port Macquarie to visit my mother-in-law, 2 nights at Forster to check out the van park for our Xmas in July event, then four nights at Stockton Beach near Newcastle including a trip to the infamous Reddo Shed of Invention to see his Supalite (I'm restoring a 1959) and his Panno (I have a Ute).
I didn't want to go back to work Monday ;D
Post by Roehm3108 on Jun 24, 2013 22:46:20 GMT 10
Post by Deleted on Jun 25, 2013 6:23:00 GMT 10
Hi Aquamum.. Damn...... I could have given you a "proper" ( not saying there is anything wrong with the one you guys made) Gas bottle mount if I knew ya needed one. I sold it at Gosford swap last weekend for $5, Good idea fitting a small gas bottle on the drawbar... saves carrying a 10KG bottle around with the extra weight . Down side is... ya never know when you are going to run out of gas. That's why you see modern vans with 2 small bottles mounted up front. one runs out ya just flick the 2 way valve to the other bottle .. then get the empty one refilled ASAP. If a big bottle runs out .. . well then .. your buggered until you go fill it up. Now go and clean up those welds and do as Ray has already suggested. Cheers Reddo
Post by Gypsy 10 on Jun 25, 2013 14:44:55 GMT 10
aquamum
Post by aquamum on Jun 26, 2013 8:30:45 GMT 10
Sorry everyone ~ That’s a “before I cleaned it up” photo . Roehm3108 - I have cleaned up my son’s welding & painted all the exposed bits ;D I have installed one of the safety gauges that also tells me how much gas is left. Reddo – I still have the original 5kg bottle that was last “checked” back when the Partridge Family was on primetime TV & I have an ice chest..... my little stove doesn’t use a lot of gas so I should be okay Gypsy 10 – no that was my youngest – the carpenter – the welder is my middle son – my eldest is in air conditioning/refrigeration – I haven’t found a use for him yet LOL a bent axle is not good – as mentioned above by Gypsy came with a 5 kg bottle that I still have if you need a photo.
Post by kaybee on Jun 26, 2013 10:10:53 GMT 10
Hiya, a bent axle isn't necessarily a big drama , find a truck axle alignment business and have them straighten it or at least view it to see if it's repairable before you pronounce it dead ;D. cheers, Col.
Post by shesgotthelook on Jun 26, 2013 15:37:42 GMT 10
Any 'good' engineering works can do your bent axle. I don't recommend one in Alice Springs. They put it on crooked & cooked the wiring. By the time we figured the crooked bit out we were 2 hours North. A really good mob in Katherine (recommended around a communal campfire) did a super job & we made it the rest of the way no dramas. Everything is fixable
Post by Gypsy 10 on Jun 26, 2013 16:24:53 GMT 10
Thanks for the info SGTL & kaybee will look into that after I take the axle off this weekend. Might even scrape some old paint off with the help of the beloved. But this Sydney rain is not helping.
maree
Post by maree on Apr 4, 2014 21:28:57 GMT 10
Hi I have several "Viscount" n "Millard" stamped Gas bottles, which r going to be (revalved) if that the right terminology. Just Wanting to know a little more about them n when They were first n last produced? How much r they worth.? Etc Could not find any info on line thanks Maree
aquamum
Post by aquamum on Apr 5, 2014 15:03:03 GMT 10
I don't know either Maree, are there any markings on the bottles beside the name?
