Post by gilbert on May 16, 2013 22:36:44 GMT 10
Hi. I have a early to late 1950s vacation van bondwood sides Alluminium front and back, can anyone tell what brand fridge they had in them. Regards Gilbert.
Post by webrake4bricabrac on May 17, 2013 7:13:23 GMT 10
Anything that early probably had an "Ice Box"!
Post by akeepsake on May 17, 2013 10:36:48 GMT 10
Hi Gilbert. Yeah I agree! An icebox would have most likely been standard equipment back then I presume it has been ripped out at some stage My 63 Millard had an icebox originally but when I purchased it off the original owner it had a Morphy Richards gas/electric fridge which fitted in nicely. Keep an eye out on eBay , gumtree etc or you may even want to ask on the forum under the "wanted to buy " section. I've seen a few on at the moment. Eg: bit.ly/110LghaCheers Andrew
Post by gilbert on May 17, 2013 22:15:30 GMT 10
Where there used to be a fridge some one had made the hole bigger so they fitted a later model fridge , but there is still a pipe sitting there for the gas, it's the same model vacation some one else on this forum has the white with the blue stripe along the sides. Regards Gilbert
Post by akeepsake on May 18, 2013 0:39:45 GMT 10
Richard I would jump at the fridge kaybee is offering great iconic fridge it'll go forever!
Post by shesgotthelook on May 18, 2013 9:08:39 GMT 10
Kaybee, if Gilbert doesn't want it I'll buy it!
I have an electrolux 3 way, yellow front that's a bit big for my vans cavity. bit of rust but works a treat if anyone is after one. $100 located Rochester Vic.
Post by gilbert on May 20, 2013 22:49:27 GMT 10
Hi just , looked again the gas pipe that is there behind fridge goes up the wall to a light on the roof no pipe for fridge they must of just run it on elec, does some one have a fridge forsale.
Post by akeepsake on May 21, 2013 10:52:41 GMT 10
Gilbert talk to Kaybee who has the Morphy Richards astral fridge ! You can easely get your gas pipe teed off the line too it or just run it on electricity !! Great fridge ! They go forever ! Be quick or someone else will grab it Cheers Andrew
Post by kaybee on May 21, 2013 16:12:10 GMT 10
Gilbert talk to Kaybee who has the Morphy Richards astral fridge ! You can easely get your gas pipe teed off the line too it or just run it on electricity !! Great fridge ! They go forever ! Be quick or someone else will grab it Cheers Andrew ...too late,mate......
Post by shesgotthelook on May 21, 2013 17:49:16 GMT 10
