Post by sportsman 1 on Aug 10, 2012 8:35:56 GMT 10
I will have a look, got similar ones in the Clipper.
If not there is a house wrecker in Melbourne I will try who may have some. This is where I got mine from last time.
Cheers, Leigh.
Post by winterwood on Aug 10, 2012 12:37:22 GMT 10
Rod,
I'm pretty sure I have some at our holiday house ... going down tonight, will check and advise.
Max
Post by dosse on Aug 11, 2012 4:40:16 GMT 10
G'day Rod..........You may like to try the mob at 63 windsor rd Redhill in Brisbane phone 0733683220 or WWW.BAKELITEINDUSTRIES.COM. old style power points and heaps more. Regards dosse.
Post by hilldweller on Aug 11, 2012 11:58:28 GMT 10
Have you tried ebay? I got mine off trademe which is the NZ equivalent. Very cheap and there were quite a few around. If they're supposed to come with little plastic headed screws ask about those too.
It's funny how much difference those little things which you wouldn't normally spend much time actually looking at make to the look of the van.
Post by cobber on Aug 11, 2012 12:14:46 GMT 10
Post by cruisindoug on Aug 11, 2012 15:28:36 GMT 10
Rod I have 1 X double with that type of switch (sort of) but with power indicator, I have one already to swap it with ... Let me know if you want it. Cheers Doug
Post by winterwood on Aug 14, 2012 16:36:33 GMT 10
Hi Rod, Found this Power Point, unfortunately it's not exactly the same as yours .... if you look carefully, you'll see that your switch is "down" whilst my switch is "up". If you can live with that slight imperfection, it's all yours! I thought I had more, but this was the only one. Regards Max
Post by humpyboy on Aug 14, 2012 19:04:46 GMT 10
So Rod, do I pull mine off the wall also?
Post by blacknomad on Oct 27, 2012 7:11:50 GMT 10
Hi Guys, I am new to this site but as I came across this thread I thought it best to reply. You see, I am a sparky and what you are looking for is kinda dangerous. You see, according to the wiring rules all switches and outlets in a caravan must be double pole. That means that the switch will operates in the active and neutral. All other items like standard household outlets are legally not to be used. I am not trying to preach, just want to help. Can explain more if you like.
