Post by brandy on Jul 23, 2012 17:21:20 GMT 10
Hi all, I'm just starting on a tear drop build and would like some advise on a good wood glue to use mainly when i join the walls to the floor. It will be screwed as well. Thanks .
Post by Deleted on Jul 23, 2012 18:27:31 GMT 10
;D Hi Brandy. Have built a couple of replica TD's . I recommend sikaflex. It has a high bond strength and you will get away with using half as many fixing screws as you would using wood glue. If you want to use any other form of adhesive i would also recommend. Selleys liquid nails.
Hope this helps Reddo
Jellybean
Post by Jellybean on Jul 23, 2012 18:59:48 GMT 10
I screwed steel angle iron onto the floor then glued and screwed the walls to that. Probably overkill but it has lasted well.
Post by brandy on Jul 23, 2012 21:15:21 GMT 10
Thanks for advice, I have used liquid nails before but wasn't sure of its strength, required on the wall to floor fixing. the sikaflex sounds like the one to use, is there a special brew that I will need. Our local store is full of young guys and they don't seem to have the knowledge of a lot of the products in the store, that is where you guys come in . thanks
Post by brandy on Sept 17, 2012 20:34:16 GMT 10
Ive made a start on the T Drop
Post by greedy53 on Sept 17, 2012 21:06:53 GMT 10
