Post by takeiteasy on Jul 5, 2012 18:52:42 GMT 10
Hi everyone - I am wondering if anyone has modified their vintage tail light frame/reflectors to contain LED components. I dislike the old clip in globes but obviously don't want to lose the original fittings. Anyone tried... or even thought about it? How did it go?
I am going to post a similar question in the caravan and camper forum, so apologies if you see this twice.
cheers, Bill
Post by greedy53 on Jul 5, 2012 19:24:33 GMT 10
i have used them in my van and kombi great never know there not standdar
Post by humpyboy on Jul 5, 2012 19:30:35 GMT 10
I have a mate who Say's that anything is possible, the impossible however will take a bit longer ;D all you need to do is locate the bits required.
Post by poddydodger on Jul 5, 2012 20:30:07 GMT 10
Bill, I've converted all the lights on my 'van, both inside and out to LEDs. This included bayonet type globes and festoon fittings on the clearance lights. A tip, I bought them on line from Taiwan and Singapore for a fraction of the cost of sourcing them locally, just be sure of the wattage etc.
pd
Post by takeiteasy on Jul 6, 2012 9:38:36 GMT 10
Thanks everyone. I wasn't aware there were LED replacement globes avaliable.
Post by beetlesbailey on Jul 17, 2012 13:48:55 GMT 10
What about 6 volt tail lights and indicators for my teardrop? Is there a unit that works on both 6 and 12 volt as someone told me once Beetles
Post by cobber on Jul 17, 2012 15:23:08 GMT 10
Post by Rattles on Jul 17, 2012 16:38:29 GMT 10
If you are using Festoon type bulbs as you are aware it is a very ordinary method of holding a lamp. With the long life of the LED festoon bulbs I suggest you solder them to the brass tags this will achieve two things will prevent the globes rotating as the LEDs face one direction only soldering will also ensure a good electrical connection.
Rattles
