Post by Roehm3108 on Jun 22, 2012 12:51:50 GMT 10
Interesting looking van, Dave.
Just to clarify, is the van located at Maryborough Vic or somewhere else?
Ray
Post by Roehm3108 on Jun 22, 2012 13:15:09 GMT 10
Thanks Dave. If anyone is interested in this van and wants someone to check it out first, I will be in that area in the next week or two (depending on the weather).
Ray
Post by isambard on Jun 22, 2012 13:57:12 GMT 10
okay to ask a few questicles here, Dave?
an enquiring mind seated to my left wants to know if the van is towable. any chance you might have that sort of info at this early stage - and at your considerable remove?
Post by overlanda on Jun 23, 2012 10:31:35 GMT 10
Have just returned from looking at the van and it has been added to the collection .It is a single axle had vacuum brakes steel framed with all the cladding pop riveted on, the inside has had some cupboards removed and a couple just sitting there perched on bricks it is going to be interesting to remove from the block as there are trees every where (was tight to drive the F250 through) so part of the recovery gear will be a chain saw .We will load it onto a trailer to bring it home next month ,we will have to allocate a corner of the factory for it. We are going to work out how to post photos as we have taken some as it sits and also post some photos of a 60s Airstream Overlander that has to be repaired in the front it has been jack knifed and received panel damage on the right hand bottom corner . Regards Gerald
