Jellybean
Post by Jellybean on Aug 1, 2010 8:00:15 GMT 10
Our friend Robyn is rebuilding her ten foot 1960s van and needs to find some of the fine diamond pattern sheeting for the outside. Does anyone know where to get some.?? Even second hand would do. Cheers John
Post by DC3Td on Aug 1, 2010 8:29:51 GMT 10
Jellybean
Post by Jellybean on Aug 2, 2010 7:08:18 GMT 10
Thanks for that. Will pass it on. Funny how the metal shop up here said you will never get that stuff anymore !!!!
Post by overlanda on Aug 2, 2010 17:21:06 GMT 10
Hi I have just gone thru the same thing and yes it is no longer made and the Rimex pattern is completly different not even a close match the only thing you could do is totaly reclad it in a new pattern.We contacted al the different suppliers and they all said the same it is not made any more but if i placed a order of 5 tonne they would run it that is a lot of sheets. I do still have all the old cladding of my 18' Wayfarer (roof ,front and back) but it has screw holes and some corrosion in places and the cost to send it to Queensland would be fairly high.
alprov
Post by alprov on Oct 12, 2016 12:20:19 GMT 10
Well folks here it is October 2016 & 6 years since the last post on this subject & still the same story " unavailable " unless a minimum order of several ton from China , frustratating as my 63 viscount could do with some of these sheets , corrosion a big problem . Just have to persavere as my future posts will show. regards al.
Post by hillbill54 on Oct 12, 2016 16:57:04 GMT 10
I,m using 3mm composite panel ( more rigid than aluminum sheeting ) with a diamond pattern for around $190 for an 8' x 4', it's polyethylene with an aluminium skin each side. I'm in the sign trade and we use it all the time, easy to handle and cut with guillotine, circular saw or jig saw. Got mine from SAS in Noble Park, Vic.- 1300 727 118
alprov
Post by alprov on Oct 12, 2016 20:18:55 GMT 10
hi hillbill54 , thanks for your responce, it would be nice if you could post a photo of what you are using, sounds interesting & also a solid product, its a bit sad that we once had a product for caravans such as the diamond pattern aluminium but now china seems to have a monoply on it , i really dont know what v/vers are going to do down the track as a lot of vans used in wrecking may still have the same ' corrosion problems ' but thanks for your post & i will see what way i go later on , at least there is an alternative regards al.
Post by hillbill54 on Oct 14, 2016 17:12:01 GMT 10
Try this.
alprov
Post by alprov on Oct 15, 2016 19:29:16 GMT 10
thanks hillbill54 , looks a great product , i will see if i can get a sample & go from there , only concern is the fit to the windows but see what happens , appreciate your time .al
Post by bayllie on Nov 8, 2016 6:32:17 GMT 10
Hi, Where are you located ? we have wrecked a 1965 10 foot viscount and still have all of the cladding ?
Post by greecelightning65 on Dec 7, 2016 3:18:10 GMT 10
Bayllie, do you have any windows from your van? Someone is hunting for one, they are near Port Macquarie, where are you?
Thanks, Sonja
Post by marinerpacer26 on Dec 12, 2016 12:08:09 GMT 10
Post by marinerpacer26 on Dec 12, 2016 12:08:25 GMT 10
Post by marinerpacer26 on Dec 12, 2016 12:10:05 GMT 10
Wrecking late 60s Millard Capri that may suit txt 0435399379 if interested and will provide photo thanks mark
Post by ivyjean on Nov 29, 2022 8:59:55 GMT 10
Hey there! Looking for the same cladding - have seen some on that site first listed but just thought I’d check if anyone that commented still has any? Thanks! Restoring a 60s coronet and just need small amount for back beside window.
