Post by ralphy on Apr 26, 2008 14:54:49 GMT 10
???G,day all im a newbie to this site, so please bear with me while i ask some bumb questions. 1. does any one know how high a sunliner is to the roof from the ground , i may have to shorten the roof on the house to get it in the back yard. cheers Ralphy
tonyh
"Dolly" 1967 Riviera
Post by tonyh on Apr 26, 2008 15:42:08 GMT 10
Hi Ralphy, ;D Welcome to the forum - I don't know a Sunliner's height but I admire your VV dedication!!!! ;D Shorting the roof of the house to get the Sunliner in - LUV it. ;D You are the just the type of person that will fit in here perfectly. Love your choice of van TOO, ;D Don't listen the old grumps that say you need wood rot, borers and white ants. Sunnys are tops - well after fibreglass Olympics of course ;D Cheers, TonyH
Post by ralphy on Apr 27, 2008 10:36:12 GMT 10
thanks for the welcome TonyH, you see the problem is ive got the width no problem at 7ft6 down the side but the eaves are going to be to low at 7ft9 ,just off to get the ladder and the makita!!!!!stay tuned,
tonyh
Post by tonyh on Apr 27, 2008 11:19:02 GMT 10
hey, before you destroy the eaves - just a thought - if you only need a small amount - up to 4" I guess - there are those wheels that are just a centre with a rubber around a flat rim, (or make up a set to suit) so you loose the height of the tyre - might be enough because my Viscount was 7'9" before I raised her 4". tonyh
Post by ralphy on Apr 27, 2008 13:16:51 GMT 10
thanks for the tip mate, hopefully picking her up from Taree next weekend so once shes home will see what needs to be done, any clues as to getting a permit to tow?? can i arrange it in QLD or does it need to be done in NSW ??
tonyh
Post by tonyh on Apr 27, 2008 15:02:28 GMT 10
I went through the permit thing - Qld not too bad - NSW a nightmare - easer to hire a tandem trailer & load her up -- also saves the problems with bearings, lights etc. tonyh
Post by humpty2 on Apr 27, 2008 18:11:08 GMT 10
To get a permit in N.S.W. the van has to be inspected and a pink slip obtained (about $30) and then a permit to move from the RTA which costs about $16 and don't forget they need a receipt of sale. You would have to get one from NSW, not QLD.
