Post by jenjon on Oct 10, 2022 10:32:54 GMT 10
Hi Can anyone help me please? I am looking for window latches for a 1976 Viscount supreme Thank you in advance. Attachments:
Post by hughdeany on Oct 10, 2022 14:44:47 GMT 10
Hi Jenjon, Those window fittings are long defunct,these are Viscount copies of Starlite windout windows which infringed copyright.The genuine ones that look the same will not fit. You will have to find someone that can 3D print them.If you join one of the fb Viscount sites you will find someone that’s knows or does that. Cheers
hughdeany
Post by Mustang on Oct 10, 2022 19:48:13 GMT 10
As Hughdeany said, on our 1977 Viscount we had the same trouble. I used black insect screen toggles on the outside to hold the windows shut, (red circle) attached with one of the screws that held the window to the van, worked fine for little expense. I tensioned each one individually by grinding a small amount of plastic from the base of the toggle. Similar to these:
Post by jenjon on Oct 10, 2022 20:41:28 GMT 10
Thank you
Post by starburst on Oct 11, 2022 17:48:25 GMT 10
