fccool
Post by fccool on Jun 27, 2022 16:48:28 GMT 10
What do people use now under the aluminium strips around the edges on plywood vans and where do you buy it?
Looks like it has some gooey tape stuff before.
Post by Mustang on Jun 27, 2022 17:06:30 GMT 10
Hi fccool, J Strip sealing is really effective if you remove the strip, thoroughly clean & apply sealer from the inside out. Butt sealing or trying to squeeze new sealer in from the side with the old gunk is only tempory.
Its a contest here to use "mastic" easily removed after a few years or "silicone" which can last the life of the van if used properly, as above.
If silicone needs to be removed its a nightmare. Some images posted would be an advantage to advice given. Cheers Mustang
fccool
Post by fccool on Jun 27, 2022 23:28:40 GMT 10
No it is freshly painted and most of the J moulds have been cleaned up with pant strpper
Post by Mustang on Jun 28, 2022 6:00:26 GMT 10
No it is freshly painted and most of the J moulds have been cleaned up with pant strpper As in the above thread , to seal them effectively they need to be removed, cleaning the inside where the sealer goes, not the outside. Cheers
Post by shesgotthelook on Jun 28, 2022 8:08:00 GMT 10
I use Sikaflex pro
Post by jdazzle on Dec 31, 2022 14:20:28 GMT 10
What do people use now under the aluminium strips around the edges on plywood vans and where do you buy it? Looks like it has some gooey tape stuff before. Hi all, I have asked this on another thread but possibly not an active one, trying again here. I am resealing the aluminium moulding around the bottom of my bondwood, the top section under the moulding looks like it has “Deniso 510 tape” under it. I inherited a pack of it from the spare parts box, looks the same. I am going to use butyl mastic on the bottom section (looks like it never had this tape) after researching this site, but anyone used this tape before? With thanks 🙏🏻. *Update, bunnings didn’t have Butyl Mastic, I got persuaded to use Sikaflex Pro+. I’ll examine my late Dad’s ancient collection of Selley caulking material tomorrow, and might use some of that instead. Still soft. His ancient Butyl mastic hard as a rock.
Post by Roehm3108 on Dec 31, 2022 16:43:04 GMT 10
Post by jdazzle on Dec 31, 2022 20:39:46 GMT 10
Post by Roehm3108 on Dec 31, 2022 22:10:24 GMT 10
If you can still find the Selleys D Mastic (black printing on green background) where you are, then I would do it. I used to know a large caravan repairer near Taree NSW who only used it too. The Sikaflex that SGTL suggests is good too, from what I've heard, but is quite a bit more expensive.
Ps. Make sure you have plenty of turps around - like most of this stuff, it's a bugger to clean off.
Post by jdazzle on Dec 31, 2022 22:54:26 GMT 10
If you can still find the Selleys D Mastic (black printing on green background) where you are, then I would do it. I used to know a large caravan repairer near Taree NSW who only used it too. The Sikaflex that SGTL suggests is good too, from what I've heard, but is quite a bit more expensive. Ps. Make sure you have plenty of turps around - like most of this stuff, it's a bugger to clean off. Roehm3108, I was wrong, Bunnings sell N Mastic, not D. Sorry to be a pain, but I can’t see SGTL’s suggestion? I bought Sikaflex Pro+, the Bunning’s guy assured me it would be ok but….others have written about Sikaflex bonding to surfaces with might, I don’t want that. Happy new year if you are in the eastern states 😊.
Post by Roehm3108 on Jan 1, 2023 7:25:49 GMT 10
Sikaflex pro is what SGTL suggested and I'm pretty sure is what she uses every restoration she has done a restoration. Happy new year to you too
Post by jdazzle on Jan 1, 2023 8:11:44 GMT 10
Sikaflex pro is what SGTL suggested and I'm pretty sure is what she uses every restoration she has done a restoration. Happy new year to you too. Okedokes. I found some butyl tape at Bunnings, I am going to give it a go. I do like to research things! Thanks again.
Post by shesgotthelook on Jan 4, 2023 7:38:18 GMT 10
Reading back through this thread has jogged my failing memory. I have used a leak seal tape on a few vans. Easy to apply & paintable. You have to hunt very hard to find a reasonable price & the correct product. May be called leak seal tape, butyl mastic tape or waterproofing tape. It's a grey putty like substance with a bandage type backing. Duram & Gripset are 2 brands. I haven't been able to find one narrower than 80mm but I guess you could cut it in half with the right tools. I have always used the following from feeBay but hopefully have found a cheaper one from 'The Water Stop Shop' in Oakleigh or Demtech Australia. www.ebay.com.au/itm/221787711159
