Post by brett930 on Sept 19, 2021 9:47:18 GMT 10
After a good look through my '66 Baravan Safari, I'm considering removing at least one interior wall panel to repair damage and provide access to run new electrical wiring.
In order to do this effectively, it looks like I'll have to remove the original overhead cabinets, which I'd like to keep.
Does anyone have any insight into the best way to do this?
Are the units simply screwed to the wall in one piece (I can see several screws in the internal frame) and with a bit of luck/care able to be removed intact, or were they constructed in situ and the only way to remove them is to disassemble them?
Post by brett930 on Sept 19, 2021 21:25:44 GMT 10
Well, after a hard day's work, the question is kind of moot - I elected to use my multi-tool and cut the wall panelling flush with the underside of the cabinets. When it comes to re-construction, I'll fit a block in the wall behind the remaining wall to support where the new sheet will sit, fit it all together with nails or screws and caulk the junction with some flexible sealant.
Post by megnephelle on Oct 28, 2021 17:06:50 GMT 10
We're looking at doing a similar thing to reach our wiring - do you mean you'll be drilling a brace block into the exterior wall? Cheers
Post by aussieute on Oct 29, 2021 8:56:15 GMT 10
Once you have the sheet flush with the cabinet use some half round quads to finish it it will look better that has been done in my jennisons to clean the cupboard joints up cheers Chris
