Calico
Jul 2, 2021 23:26:05 GMT 10
Post by Tank on Jul 2, 2021 23:26:05 GMT 10
hi everyone, need some advice on repairing calico on the roof. The structure is fine but the calico is starting to split and slightly lift. Thank you
Post by Roehm3108 on Jul 3, 2021 8:06:45 GMT 10
Hi Tank and welcome as a guest. Would be interested in knowing what type of van you're restoring. Generally, when the calico lifts, it means you have to strip it off and replace it. Not very difficult, just messy. Remove the old calico and sand the surface smooth. I generally put on a layer of primer/sealer/undercoat. then thickly lay on a good exterior acrylic house paint a section at a time and roll new calico on, making sure you soak it fully and remove air bubbles. do this till you've done the whole roof. I generally then roll on another 4-5 coats of topcoat to seal it properly. Good for another 50 years!
Calico
Jul 3, 2021 10:17:18 GMT 10
Post by shesgotthelook on Jul 3, 2021 10:17:18 GMT 10
Tank
Post by Tank on Jul 3, 2021 12:23:31 GMT 10
Thank you for allowing me to join your group. I am after some advice on repairing Calico on a 1956 bond wood van. The product has some small splits and is starting to lift. Thanks in advance for you help
Post by Don Ricardo on Jul 3, 2021 14:43:27 GMT 10
Hi Tank, Welcome to the forum. Great to hear that you're going to repair the roof of your van. Have you seen the replies to your first post on another thread about repairing the roof? A couple of forum members have already provided some info, so I've used my ability as an admin team member to merge the other posts into this thread. I hope that helps and that you find it all (just look higher up this thread). We'd love to hear a bit more about your caravan too. You mentioned that it was built in 1956. What type is it? If you'd like to post some photos, there's info on how to do that if you click on this link. Don Ricardo0
