Post by chrisp219 on Apr 13, 2021 22:52:03 GMT 10
Hi knowledgebank
I'm interested in purchasing a 1967 Olympic Debonair. I am a rookie in the caravan world and am trying to find out if this type of caravan is insulated but can't find anything on the net. Hoping someone here might be able to help me out.
Thanks in advance! Chris
Post by Warrenk on Apr 14, 2021 11:41:03 GMT 10
If the Debonair has not had any renovations done to it there will be no insulation in the walls or roof. There is some foam rubber in the top cupboards, but it is more to stop condensation than insulation.
Post by gregh on Apr 14, 2021 12:50:33 GMT 10
Hi knowledgebank I'm interested in purchasing a 1967 Olympic Debonair. I am a rookie in the caravan world and am trying to find out if this type of caravan is insulated but can't find anything on the net. Hoping someone here might be able to help me out. Thanks in advance! Chris Actually the roof does have roughly a 50mm close cell solid foam insul core which provides a surprisingly good insulation. The walls have none, but because it is fibreglass paneling, it is somewhat cooler then an aluminum or bondwood van. The later model Olympics which had fibreglass internal paneling (ie not plywood) were a bit cooler in summer I've had the advantage of owning both at the same time - old alloy and fibreglass. The Olympic fireglass vans are much cooler in summer; particularly with the large roof vents. - I cant comment for a winter scenario. Greg
Post by blue7373 on Apr 15, 2021 20:22:02 GMT 10
Post by blue7373 on Apr 15, 2021 20:26:31 GMT 10
HI CHRIS I ACTUALLY HAVE JUST PURCHASED A 1967 OLYMPIC DEBONAIR THAT I AM RESELLING AS I AM KEEPING THE SECOND VAN THAT WAS INVOLVED IN THE SALE,ITS A ONE OWNER, I THINK THE FRIDGE MAY HAVE BEEN REPLACED AT SOMETIME BUT NOTHING ELSE HAS CHANGED, STILL ORIGINAL NUMBER PLATE AND ANNEXE, VIC REGISTRATION ,YOU CAN CONTACT ME HERE OR ON 0458666186 THANKS DARREN.
