Post by davo7th on Jan 10, 2021 16:41:51 GMT 10
Hi all, Could anyone recommend an electrician down this way to help me with wiring my whole van? It's an old 10 foot bondwood I've been slowly working on, and I need to wire before I put the new external ply on the walls. 90% of the old wiring was removed before I got hold of it so it's virtually start from scratch. The electrical stuff is not exactly my strong suit, so I need advice as to what put in etc. I've tried to research 12 and 240 volts and inverters etc. but I'm going round in circles a bit and not confident with getting it right. Ideally I could help with running wires etc and purchase batteries etc ahead of time. Thanks, Davo
Post by Mustang on Jan 16, 2021 17:00:24 GMT 10
Before you invest a significant sum into a leccy usually $100 an hour, I have gained a lot of support from Collyn Rivers caravan books. Here12v is not dangerous , but you may prefer a qualified guy on 240v. When you find a guy ask for a quote & what you need to do with running cables around the van, some prefer conduit, others not if you are using quality cable. Generally you keep the 240 cable & the 12v someway apart, you could save hundreds by doing a lot of the lug work yourself. A suitable guy may be able to keep an eye on you & simply perform the technical connections. I have cabled 3 x vans with no previous experience.  Good renovating Mustang
