Post by fordofalcon on Jan 9, 2021 12:19:54 GMT 10
Hi everyone, I’m sure this has been asked before. Just looking for advice on best paint to use for the exterior (sides) of our 1960 Franklin, the surface is still pretty good although I will be filling a few old screw holes and cutting out some rot, approx 50mm at the base. I would like to spray it and finish with a shiny/gloss surface. Can or should I use a water based Acrylic outdoor house paint ? Can I spray it with standard automotive spray gun? Thinning of the paint - what mixtures ? Any advice or past experience will be appreciated, thank you.
Post by Mustang on Jan 10, 2021 6:45:24 GMT 10
I used Norglass marine paint & highly recommend it. They have a great help line.
Post by fordofalcon on Jan 15, 2021 17:30:48 GMT 10
I used Norglass marine paint & highly recommend it. They have a great help line. Thank you Mustang Did you spray it with an automotive spray gun ?
Post by Mustang on Jan 16, 2021 15:56:25 GMT 10
I used a friend & his gear, I'm not sure of the nozzle size , but the same gun he uses on cars. We needed to hook up a second compressor, as mine (handy man size) was not keeping up the required pressure. Would pay you to rent a large capacity compressor for the job, as we used two pack.
You need a full helmet & suit.
With Norglass you can soften the finish with a powder, our job ended up semi gloss, the paint is second to none, for quality. Cheers.
