brick
Post by brick on Dec 8, 2020 11:21:57 GMT 10
I have a old van viscount Ambassador The front end has been replaced It is old log on the sides split windows both ends And white bond wall and roof Found a number inside on the wall E 41 could that be the van number And what year june 1968 Need some help
Post by Don Ricardo on Dec 8, 2020 13:25:27 GMT 10
Hi Brick, Welcome to the forum. 'E41' sounds like the beginning of the serial number for your van. If the serial number is/was 'E41xx', in other words with two extra digits, then that would indicate that your van was built in 1969. That would fit with the log cabin cladding I think you are referring to. In any case the serial number for an Ambassador around that period would normally be 'E' plus four numbers. If you can post some photos of your van we can probably confirm the year for you. There are instructions on how to post photos using the 'Add Attachment' button if you click here. However, I notice that you are posting from your mobile, so make sure you follow the additional step to find the 'Add Attachment' button - you have to scroll right down on the forum screen and click on 'Desktop'. If that all sounds too confusing, email some photos of your van and I'll happily post them for you. My address is caravanhistory@gmail.com Don Ricardo
