Post by sportsman 1 on Nov 15, 2020 8:58:06 GMT 10
I have a new axle for sale. I had this made for the Clipper but eventually went for a drop axle instead.
It is 45mm solid square, total length is 1820mm between tips of stub axles.
It has square plates welded on for attaching brake backing plates.
It DOES NOT have any brakes or hubs so you can decide what brake setup or stud pattern drums or hubs you wish to use. It can be used without brakes fitted if desired.
It should be suitable for most size vans but check your width first.
It was fitted for a few weeks only and only one weekend trip so is essentially brand new.
$80
Contact Leigh 0407 884 869
Pickup from Lilydale or Blackburn, Vic.
